1991 Ford E-Series Van Wet plugs
RJHAYNES77
Engine Performance problem
1991 Ford E-Series Van V8 Two Wheel Drive Automatic 178k miles
what is the most common problem that cause the plugs to become soaked with fuel, and cause a no start? i've checked for spark and thats good . where is the fuel pump relay located on the van.
Jan 24, 2010 at 10:09 AM
MERLIN2021
  • 17,250 POSTS
Lack of spark. no before you get it running, change the oil and filter, then a new set of plugs and wires, then to test for spark, remove the fuel pump relay so you dont soak the new set! Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
https://www.2carpros.com/dia/how_to_check_compression.htm
https://www.2carpros.com/dia/index.htm
Jan 24, 2010 at 10:16 AM
