Engine Performance problem
1991 Ford E-Series Van V8 Two Wheel Drive Automatic 100k miles
I am having problems with the idle on my van it has a 302 in it. I recently had the frame rail fuel pump replaced. And after that i started having problems with the idle. When i start it in the morning it starts to idle up when i catches itself and levels off before going high enough.Then when starting to drive when its cold it stumbles a little. Then once warmed up it will run ok . Then after driving when i put it in park it idles down and just dies. It doesnt run rough or anything its like i just turned off the key.
I did replace the iac about 5k ago. If i recall correctly the symptoms are the same as the last time.
I think that the shop who diagnosed the fuel pump problem may have sprayed starting fluid in it possably messing up the iac. Am i correct im assuming that this is a possability? I have heard of this before but not sure if it is correct.
I am sorry guys about the lack of a donation but guys i have thrown so much money into this van already im just about broke the fuel pump escapade was 540.00 that was a week ago and i still owe for it sorry again. I would really appriciate any help you can give to prevent me from having to go back to shop
Feb 3, 2009 at 9:56 AM
