1991 Ford E-Series Van gas line leak
BRANDISE
1991 Ford E-Series Van Automatic
My van leaks everytime I fill it with gas...it started out when I put anymore than 10.00 at a time, and now any amount. Looking underneath it looks like it's leaking from a tube between two clamps in multiple spots. My question is since it's a straighht hose is it still the fill line or is it coming from somewhere else. It does not leak after you leave the pump.
Dec 10, 2009 at 11:37 PM
BLACKOP555
  • 10,386 POSTS
there are a fill hose and hose clamps. make sure the hoses are not cracked, pinched and the hoseclamps are tight and circular not bent.
Dec 11, 2009 at 6:41 AM
TEDLEPP
  • 6 POSTS
There was a recall on 89 to 91 e350 about bad O
rings in selector switch. caused gas to flow to rear tank
and overflow
Feb 10, 2010 at 8:41 AM
