1991 Ford E-Series Van fuel
16,000 MILES • V8 • 2WD • AUTOMATIC
LAVANDEM
I have changed fuel pump, fuel filter, checked lines and when weather gets warm and I drive the van it will start to vapor lock , surge and sometimes quit. The temperature gauge does not show the van warm and I cannot figure out what else it could be. It has the 460 7.5 motor in it.
May 30, 2010 at 8:54 AM
  • 75,988 POSTS
Inspect and test all the following listed below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 30, 2010 at 8:59 AM
