1991 Ford E-Series Van 91 ford van NEED HELP PLEASE
1991 FORD E-SERIES VAN
185,000 MILES • V8 • 2WD • AUTOMATIC
HAMMRS1
hello.5.8 litre gas auto trans. my van stalled the other day and wouldnt restart. when i got it home it would start and run for about 30 sec. then would shut off like it ran out of fuel. replaced filter and front fuel pump and pressure regulator. it tried to run but is popping through the intake, then will run fine, then pop again and die. it has 2 fuel tanks, also replaced the ignition module.please help. im at my wits end here.
Jun 1, 2008 at 6:10 AM
ONEI3RD
  • 5 POSTS
I had a car with similar problems it turned out to be a timing sensor. If possible have your van checked on a computer. also dont overlook the simple things like coroded or lose battery cables and fuses, usally the simplest things go wrong and are often over looked because people panic
Nov 24, 2008 at 7:40 AM
