Hi, my name is glenn. And i have a 90' ford van E150, straight 6, 4.9, it has a push button overdrive transmission, the trans is E transmission. It will not shift right. It will not shift into other gears. Sometimes it starts in second gear. If you stick it in neutral, then drive, it will shift fine, sometimes that is. This is the third trans i put in this van in the past six months, and every trans was the same. What could the problem be?
Oct 8, 2009 at 3:04 PM
