1989 Ford E-Series Van Ignition Key
VICWRECK
Electrical problem
1989 Ford E-Series Van V8 Two Wheel Drive Automatic
Hi, My ignition seams to bind, does NOT return when released. So HOW do I remove the key cylinder to put a new one in? I also keep getting a dead battery, so I bought a brand new one, and that also dies whinin a week, so maybe the key switch, everything is OFF on the dash. Thanks
Sep 5, 2008 at 9:59 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:fa7d11eebb="vicwreck"]Electrical problem
Hi, My ignition seams to bind, does NOT return when released. So HOW do I remove the key cylinder to put a new one in? I also keep getting a dead battery, so I bought a brand new one, and that also dies whinin a week, so maybe the key switch, everything is OFF on the dash. Thanks[/quote:fa7d11eebb]
Sounds more like the Ignition Switch not your Lock Cylinder and Key.
The Ignition Switch is located under the dash on the steering column.
Sep 5, 2008 at 10:05 AM
