1989 Ford E-Series Van engine wont crank
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVEPIERSALL
turned van off,tried to start about 5 minutes later and would'nt crank.battery is o.k.,lights and everything else working fine.i notce when i turn the key to the crank position it just stays there it does'nt turn back automatically.do you think this is something w/the ignition switch or starter/solenoid?
Apr 18, 2010 at 3:39 AM
  • 75,988 POSTS
Hi davepiersall, Welcome to 2carpros and TY for the donation
Replace the ignition switch any other problem get back with me-
Apr 18, 2010 at 9:30 AM
