1988 Ford E-Series Van To much fuel
223,000 MILES • V8 • 2WD • AUTOMATIC
DOU1220
I have a 1988 Ford E250 van and it loads up on fuel like a rich running carb but its fuel injected. It fouls the plugs about every 6 months because it gets to much fuel and when you change them you can see the gas on them. When I'm sitting at a stop light it loads up and wants to cut off i put it in N but this just helps but it still runs rich. Sometimes when you go from a dead stop it will cut out and back fire. I try to keep it in good running order I have changed the plus and put a new fuel pressure reg on it but that didn't fix it. Thank you for your time hopefully you can help
May 15, 2010 at 11:05 AM
  • 75,988 POSTS
Injectors could be leaking and fuel return line clogged and other causes
Defective Oxygen Sensors.
Coolant temperature sensor out of calibration.
Restricted air intake system.
_________________
May 15, 2010 at 11:10 AM
