1988 Ford E-Series Van How to change Oil Cover Gasket
LIRO0917
Engine Mechanical problem
1988 Ford E-Series Van V8 Two Wheel Drive Automatic
How do you change the Oil Cover Gaskets on this Van I can get one side off but the other is a problem. Is there somewhere that I can get a picture or video of this or is there a special tool that will make this easier?
1988 Ford Econoline Van 5.8 motor V8
Thanks!
Sep 30, 2008 at 7:17 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:d690a454cc="liro0917"]Engine Mechanical problem
Thanks![/quote:d690a454cc]
No ther are no special tools or an easy way to do it...
You will have to remove the Plenum in order to change the one Valve Cover Gasket.
Sep 30, 2008 at 7:37 AM
