1987 Ford E-Series Van
39,500 MILES • V8 • 2WD • AUTOMATIC
LEO SCHMUCK
My engine runs good when cold, at normal temp the engine shuts down and takes 30 minutes or so to cool down for a restart. replased, carb, plugs,
cables, pump, distribitor, plugs, battery, new ignition box from MSD, new coil. Some times it will run OK for weeks and then back to shut down. Reading some of your answers from other cars problem, you will most likely tell me to change the Ignition switch.
Please give me a answer. Thank you for your time.
Leo Schmuck. My E-Mail printemp2@msn.com
Jan 11, 2008 at 3:24 PM
MERLIN2021
  • 17,250 POSTS
What is the no start symtom? any clicks? does it crank slow? Or no noise at all?
Jan 11, 2008 at 11:51 PM
LEO SCHMUCK
Engine kranks " NORMAL " after shut down.
Jan 12, 2008 at 6:05 AM
MERLIN2021
  • 17,250 POSTS
If it has a tach, check the wire, it could be intermittently grounding...
Jan 12, 2008 at 8:10 AM
