HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
E-Series Van
Fuel System
Fuel Filter
Replace/Remove
1986 Ford E-Series Van fuel filter
SRKSALESREP
MEMBER
1986 FORD E-SERIES VAN
V8
2WD
AUTOMATIC
50,000 MILES
Where is the fuel filter located?
Saturday, January 24th, 2009 AT 6:04 PM
MECHANIC
It is under the van on the left side below driver's seat. You need a special tool to remove it that is available in most autoparts stores.
Saturday, January 24th, 2009 AT 6:19 PM
BLUELIGHTNIN6
MECHANIC
Under vehicle, driver side, below seating area, rear of engine, mounted on frame rail in fuel line.
Thanks for using 2CarPros. Com!
Saturday, January 24th, 2009 AT 6:20 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Filter Replace/Remove Content
2002 Ford E-series Van Fuel Filter
How To Remove And Install A Fuel Filter On A 2002 Ford E350 Super-duty 5.4 Gas Engine. And Where Is It Located. How Do I Deppressurize It.
Asked by
ADRIANA39
2002
FORD E-SERIES VAN
GUIDE
Fuel Filter Replacement
A fuel filter is designed to remove partials and contaminants from the fuel before they enter the fuel injection system. Most cars have one or two filters, the primary...
1994 Ford E-series Van Fuel Filter Removal
How To Remove Fuel Filter From This Vehicle.
Asked by
desidevall
1 ANSWER
1994
FORD E-SERIES VAN
Change A Fuel Filter
How Do You Change A Fuel Filter On A 1992 E350 Diesel Ford Van With A 7.3 Liter Engine. (Automatic Transmission)
Asked by
jomel
1 ANSWER
1992
FORD E-SERIES VAN
1989 Ford E-series Van Fuel Filter
Engine Mechanical Problem 1989 Ford E-series Van V8 Two Wheel Drive Automatic New To This Van And Need To Know Where The Fuel Filter...
Asked by
trents1979
1989
FORD E-SERIES VAN
Hi Where Is The Fuel Filter Located?
Asked by
bart ryk
2002
FORD E-SERIES VAN
VIEW MORE
Replace Fuel Filter Chevrolet S-10
Tune up
Fuel Pump Pressure Test
