1978 Ford E-Series Van Engine stalls
JOSHUALEAF
  • 1978 FORD E-SERIES VAN
  • V8
  • 250,000 MILES
The van will start fine, and warm up, but maybe stalls during this time. Then it will run for 5 or 10 minutes on the road and then stall. It then sometimes starts again, or sometimes not. The mechanics at the shop said most likely the fuel pump. So I checked the fuel line coming into the carburator when it stalled and there seemed to be fuel there still, but maybe not enough? I took the air filter off, and then she seems to run fine. Is it worth changing the fuel pump to see?
Friday, November 20th, 2009 AT 2:25 PM
HIPPO800
  • 29 POSTS
How old is the carb?
Sometimes the accelerator pump diaphragm gets old, and leaks.
Install an MSD Blaster SS coil for a better spark.
Works with stock ignition box.
Use stainless lockwashers on coil screws for safety.
And you don't give compression figures, vacuum readings, etc.
Hmmnn.
Wednesday, February 3rd, 2010 AT 8:17 PM
Related Engine Stall While Driving Content
