1992 Ford Custom After Running a while My truck won't start
181,869 MILES • V8 • 4WD • MANUAL
DAVHRT1
I recently bought this truck. In the morning it starts up fine. But after it runs a while, if i shut it off it won't fire up. If i let it set for several hours it starts right up again. It does miss some too at a certain spot in pressing the gas peddle down. Also when im trying to start the engine after its ran a while I get a heavy gas smell. It is fuel injected so i don't press on the gas peddle to start it. I did change the plugs but that didn't help.
Aug 2, 2010 at 11:31 AM
  • 75,988 POSTS
If it refuses to start don't wait for nothing- do below to find out if its fuel or spark problem that's causing it not to start-something has to give.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Aug 2, 2010 at 11:46 AM
DAVHRT1
Thanks ill check on that. One thing i forgot to mention earlier is. I can push start it just fine and it will run till i shut it off. Then it's back to not firing up when i turn the switch until it cools off.
Aug 3, 2010 at 8:04 AM
  • 75,988 POSTS
Sounds like the ignition switch is failing
Aug 3, 2010 at 8:18 AM
