Sqeaking and popping
MIKE23
  • 5 POSTS
I have a 2001 Ford Crown Victoria LX 4.6 L V8 with 85,300 miles on it? I have recently put some 22 inch rims on and now when I pull in to a parking lot space it makes a pop noise, its a pop only when I do this. Also my shocks are good but I have permament sqeaking in the front left of my car it doesn't sqeak if I bounce the car or parked, just when I"m driving it sqeaks it sounds like something is loose but it is a continous sqeaking while driving and it's only in the front on the driverside. Why and what can I do to fix this?
Jun 30, 2007 at 3:48 PM
MERLIN2021
  • 17,250 POSTS
Is it worse going over bumps? If yes check you upper control arm bushings...
Jul 1, 2007 at 6:04 AM
SIMONK
  • 8 POSTS
sway bar lins will make this kind of sound. The only way to diagonize them is to disconnect and test drive without them. if the noise disappears guess what? time to replace them.
Aug 22, 2007 at 3:28 PM
93SC
  • 13 POSTS
sway bar links, upper control arm bushings, but also get some good grease and put alot on the hood stops and turn limit pockets
Sep 15, 2007 at 2:37 PM
