Hanging door.
JUST_GRETA
  • 7 POSTS
Hi. I have a '94 Crown Vic w/140300 miles. The driver's side door hangs when open, and I must lift it up to close it. What's the possible reasons, and might it be a simple thing to fix? Thanks.
Oct 7, 2007 at 9:25 AM
FAIRRACING31
  • 150 POSTS
Sounds like your door hinge bushings are bad. You can pick them up at your local auto parts store. Use a punch and hammer to knock them out. Tap the new ones in. Sometimes its easier to remove the door.
Oct 7, 2007 at 10:39 AM
JUST_GRETA
  • 7 POSTS
Thank you! Very much appreciated.
[quote:1488c1ef57="fairracing31"]Sounds like your door hinge bushings are bad. You can pick them up at your local auto parts store. Use a punch and hammer to knock them out. Tap the new ones in. Sometimes its easier to remove the door.[/quote:1488c1ef57]
Oct 7, 2007 at 11:05 AM
