ford crown vic 1986, 95,000m, 5.0
ALANBEN
  • 5 POSTS
Hi. Changing lower ball joints found no rivets yet. Is it OK to separate the joint from the arm or not possible at all? Thanks
May 18, 2007 at 8:51 PM
BOOTDOG
  • 665 POSTS
if i'm not mistaking i believe the lower ball joints on this model are pressed in. to remove you need to jack the vehicle from the lower control arm, you'll need a ball joint separator to separate the steering knuckle from the the ball joint. move the knuckle assembly out of the way and whack the ball joint with a hammer till it pops out. in order to install you'll need a ball joint press to press back in the control arm. hope this helps
May 19, 2007 at 1:12 AM
BOOTDOG
  • 665 POSTS
here's a pick of the tools
https://images.2carpros.com/forum/automotive_pictures/44087_G_14148G_SW_1_1.gif
ball joint press
https://images.2carpros.com/forum/automotive_pictures/44087_G_14159G_SW_1_1.gif
ball joint seperator
May 19, 2007 at 1:20 AM
