Ford Crown Vic
CPINSON
I have a 1992 Ford Crown Victoria (4.7) with 150,000+ miles on it. This morning the battery light came on. At first it would light up at speeds below 55mph, and then go off once I past 55mph. Then it stayed on continuously. By the time I made it home from my 45 mile trip the Anti Lock break light was going on and off, my signals weren't working, and my power steering was failing. The battery was replaced last year, and the alternator recently tested fine. I am at a loss for what could be causing this. The alternator is easy enough to replace, but I am concerned about the signals, antilock break light and steering. Would these warning lights come on when an alternator is failing? Any ideas?
Apr 2, 2007 at 10:39 AM
SIRGIBBY
  • 32 POSTS
How's the belt look? If the belt is slipping it'll make the alternator not do its job properly.. and if the alt wasn't workin properly that could explain the other lights..
Apr 2, 2007 at 11:12 AM
CPINSON
Didn't think to check the belt. I'll start there. Thanks.
Apr 2, 2007 at 11:20 AM
