ford 1992 crown victoria
1992 FORD CROWN VICTORIA
DEWDROP1972
I have a 1992 Ford Crown Vic. I started the car and went to pull out of my driveway and it seemed like someone had just reached over and shut it off. When I went to restart it all it done was click. I changed the starter, and all it still does is click. I'm needing to know what else I can do?? Is the motor locked up?? The belt will not turn free handed.
Feb 14, 2007 at 2:46 AM
MIKE H R
  • 3,094 POSTS
to check to see if the engine is frozen up is use a breaker bar and a socket for the bolt on the idler
pulley. then move the braker bar back and forth, turning the engine. this will tell you if the engine is seized up.
Feb 17, 2007 at 12:09 PM
