Can't Loosen Fan Clutch Hub-
1992 FORD CROWN VICTORIA
TPOOLE
I am trying to change the water pump on my 1992 Crown Vic. I bought the tool to help take off the fan clutch but I can't get it to loosen. Is it possible to remove the water pump as 1 piece and then remove the fan clutch?
Mar 15, 2007 at 6:11 AM
DWOODS9988
It's easier to leave the belt on to take off the clutch. Use a hammer to hit the end of the wrench counter clockwise or in the direction of engine rotation to loosen. look at the fan, and turn it to make the air move towards the engine, thats the direction the engine rotates . The quick jar seams to work better than a hit with a hand. Hit the wrench with the hammer the same way you would hit it with your hand.
Mar 24, 2007 at 7:59 AM
MERLIN2021
  • 17,250 POSTS
To prevent silicone fluid from draining into fan drive bearing, do not store or place drive unit on bench with rear of shaft pointing downward. The removal procedure for either type of fan clutch assembly is generally the same for all cars. Merely unfasten the unit from the water pump and remove the assembly from the car.
The variable speed fan with flat bi-metal thermostatic spring may be partially disassembled for inspection and cleaning. Remove screws holding the assembly together and separate the fan from the drive clutch. Next remove the metal strip on the front by pushing one end of it toward the fan clutch body so it clears the retaining bracket. Then push the strip to the side so that its opposite end will spring out of place. Now remove the small control piston underneath it.
Check the piston for free movement of the coupling device. If the piston sticks, clean it with emery cloth. If the bi-metal strip is damaged, replace the entire unit. These strips are not interchangeable.
When reassembling, install the control piston so that the projection on the end of it will contact the metal strip. Then install the metal strip. After reassembly, clean the clutch drive with a cloth soaked in solvent. Avoid dipping the clutch assembly in any type of liquid. Install the assembly in the reverse order of removal.
The coil spring type of fan clutch cannot be disassembled, serviced or repaired. If it does not function properly it must be replaced with a new unit.
Read this guide, it will help
https://www.2carpros.com/articles/fan-clutch-removal
Mar 24, 2007 at 3:14 PM
