2007 Ford Crown Victoria Low coolant
2007 FORD CROWN VICTORIA
41,000 MILES • V8 • 2WD • AUTOMATIC
BARAAK79
Hi the coolant level become little bit low around 0.5L less than the normal level and I never added any water from the time that i bought the car . also the cooling fan mostly works on the high speed . So is that normal that coolant level become littel low after this distance or there is a problem with the cooling system ??????
Oct 20, 2008 at 3:23 AM
2CARPRO JACK
  • 11,533 POSTS
It shouldnt lose any coolant, it is a sealed system.Look for any stains where coolant might be seeping from.If you cant see anything, have the cooling system pressure tested for leaks
Oct 20, 2008 at 7:43 AM
