Found out what you were talking about, only had to read your answer again. turned on hazard lights pushed brake pedal and the hazards kept flashing, are they supposed to stop flashing? no other issues with the turn signals, hi/lo beam or wipers. is there any tests, that can be done besides replacement to determine if it is bad? thank you
May 19, 2021 at 11:44 AM
(Merged)
