2004 Ford Crown Victoria Drivability issues
2004 FORD CROWN VICTORIA
148,052 MILES • V8 • 2WD • AUTOMATIC
P71MOTORSPORTS
I have an '04 Ford CVPI with an '03 motor, trans, and computer swap. (everything CVPI) I've replaced the intake manifold due to a hair line crack. Cleaned the throttle body, intake elbow, inspected the fuel injectors, and changed the fuel filter- due to lean mixture codes on both bank one and two. I've changed the MAF sensor and all for O2 sensors also. Now I'm having random, multiple cylinder misfires (P0300 and P0316). I've changed the spark plugs and all eight coil packs. Still no improvement. During driving at medium rpm's it runs perfect, but at low rpm's and at high rpm's I'm still getting a skip. The skip is never on the same cylinder and I'm at wit's end. Any advice?[img:b60e706ed7]http://www.2carpros.com/forum/automotive_pictures/575956_P7050035_1.jpg[/img:b60e706ed7]
Sep 23, 2010 at 10:11 AM
