2004 Ford Crown Victoria differential clutch spring
2004 FORD CROWN VICTORIA
JIM BYBEE
Drive Train Axles Bearings problem
2004 Ford Crown Victoria V8 Two Wheel Drive Automatic
Does it take a special tool to depress the diff clutch spring into the space between the axle gears?
Oct 19, 2010 at 3:59 AM
WAY2OLD
  • 195 POSTS
If it is an "s" shaped spring, just use a screwdriver to pry it out of the spider and side gears. It should come out fairly easily.
Oct 19, 2010 at 12:10 PM
