2003 Ford Crown Victoria miss on slight accelleration
104,000 MILES • V8 • 2WD • AUTOMATIC
TOMWHITE
the engine displays a miss when the accellerator pedal is slightly pressed. Pressing it down more makes the miss go away. Going up a slight hill, since it usually requires a slight increase in fuel/accellerator produces the same problem. Any idea/
Sep 25, 2009 at 11:36 PM
RACEFAN966
  • 5,029 POSTS
OK let me ask a couple questions first so I can better help. Is the check engine light on? How old are the spark plugs and fuel filter? Is the air filter clean? Get back to me and we will go from there.
Sep 26, 2009 at 1:50 AM
TOMWHITE
Thank you. I am going to begin with the fuel filter and work forward from that point. I suspect the spark plugs may need changing and will attend to that. Some suggested the EGR valve but I'll hold off on that one until I am desparate. LOL
Thanks again
Sep 26, 2009 at 2:42 AM
RACEFAN966
  • 5,029 POSTS
Ok let me know how it runs after you change the filters and plugs. As for the EGR we can test that is you are still having problems. Get back to me and we will go from there.
Sep 28, 2009 at 6:02 AM
