2003 Ford Crown Victoria Intermittant stiff steering
2003 FORD CROWN VICTORIA
133,000 MILES • V8 • 2WD • AUTOMATIC
KDORSEYBIZ
I have a 2003 crown vic p71 and the steering will get real stiff for a while then loosen back up and repeat every so often. The serpentine belt was worn and streached enough to rub together so I replaced the belt and the fluid level was not an issue. Is this more likely the pump ro the rack and pinion??
Aug 6, 2010 at 3:33 AM
WAY2OLD
  • 195 POSTS
These are known to have the little "U-joint" in the steering shaft freeze up and cause that problem.
Aug 8, 2010 at 9:36 AM
