2003 Ford Crown Victoria Fan blower motor
TEXASBIGBOOMER
Air Conditioning problem
2003 Ford Crown Victoria V8 Two Wheel Drive Automatic 98K miles
have auto temp control, but fan stopped running on any speed other than MAX, on any switch. replaced both 40amp fuse and hicurrent relay (5 pin box), but no change. Possibly the control head, or a resistor on the blower motor? If the latter, can it be repaired or motor just replaced?
Aug 2, 2010 at 5:22 AM
DOCFIXIT
  • 18,828 POSTS
Would think a faulty Electronic Automatic Tempeture Controler center dash. If front blower relay did not fix then EACT must be the culprit.
Aug 2, 2010 at 7:48 AM
WAY2OLD
  • 195 POSTS
Usually when the blower resistor fails, it will default to the max position. It is located behind the passenger side valve cover on the A/C plenum.(black plastic housing under hood)
Aug 2, 2010 at 10:58 AM
