2003 Ford Crown Victoria Dash lights
SKYCOP46
Electrical problem
2003 Ford Crown Victoria V8 Two Wheel Drive Automatic
After load testing the battery, why do all of the lights on the dash start flashing when I turn on the ignition? I cannot get them to turn off.
Aug 28, 2010 at 12:48 PM
  • 110,248 POSTS
Have you tried disconnecting the battery and then reconnecting it?
Sep 3, 2010 at 12:59 AM
SKYCOP46
Thanks to the recommendations about checking the load on my battery as well as disconnecting the battery. However, I finally figured out that the security system was making all the dashlights flash and wouldn't let the car start. I Hit the lock switch and then the unlock switch and problem was solved. Just dumb on my part I guess. Thnx
Sep 10, 2010 at 2:45 PM
  • 110,248 POSTS
That was an easy one. I'm glad you got it working. Let us know if you have questions in the future.
Sep 10, 2010 at 5:38 PM
