Engine sputters under acceleration?
93,000 MILES • V8 • 2WD • AUTOMATIC
HOLMESFAM
vehicle occasionally sputters under hard acceleration
Oct 13, 2008 at 9:16 PM
RICK 08
  • 54 POSTS
May have a bad plug wire, consider scanning codes This problem will not always turn on check light. a code reader should tell you which cyl is failing if this is the case. Some plug wire sets are costly (as much as a cheep scanner) so the scan might help save you dollars.. These guides will help us fix it.
and
Oct 27, 2008 at 7:58 AM
JACOBFEGLEY
  • 8 POSTS
I have a 98 ford crown victoria p71 police interceptor that has tranmission shudder. how can i fix it ?
also the car at idle will get a sound like something is slapping in the front of the engine it comes and go's its not always there it shows up more in warmer weather and dosent affect performance and dosent do it when rpm's raised what could it be it has 171,000 miles on it
Oct 19, 2020 at 9:51 AM (Merged)
MERLIN2021
  • 17,250 POSTS
well the shudder could be clutches or torque converter...nedd more info, How fast are you going before you get it, The slapping? check the serp belt or anything flapping around under the car. See if the shroud is loose.
JACOBFEGLEY
  • 8 POSTS
the shudder comes about 25mph and higher and if ya cruze but if ya keep ur foot in it theres no shudder . and the slapping is only at idle and its coming from the engine
KEVINLOKEN
  • 74 POSTS
hey there im looking at buying a 1996 ford crown vic and all i was told so far is that it sputters on heavy acceleration and the engine check light is on any idea what this could be thanks
DAVE H
  • 13,383 POSTS
could be numerous reasons for the splutter ? MAF sensor .. bad fuel .. clogged injector ..bad pump .. etc etc. better off having them take the vehicle to a good autoparts store (autozone etc.) and have them read the codes ..most do this free .. repost with the codes for a better diagnosis
CHUCKYB10
  • 17 POSTS
When driving, it kind of sputters like its not getting fuel, I can drive it like this but it jerks back and forth.
CARADIODOC
  • 34,412 POSTS
That isn't much to go on. You didn't even say which fuel system you have. Some cars still had a carburetor, and some had multi-point fuel injection. About the only thing you can do for this symptom, if you have fuel injection, is to check the fresh air tube between the mass air flow sensor and throttle body for cracks or leaks. If any air sneaks in that doesn't go through the mass air flow sensor, the Engine Computer won't command enough fuel to go with it. That will cause a hesitation or stumble on acceleration.
CHUCKYB10
  • 17 POSTS
Yeah my fault in new to this, 5.0 efi, 302, and it jerks back n forth, usually after about 50 mph, now its acting like this, no matter the mph, I'm a beginner to working on cars, but I want to know everything. All info is very appreciative, thank you
CHUCKYB10
  • 17 POSTS
What is the throttle body?
CARADIODOC
  • 34,412 POSTS
If you think you'd like to get into working on cars, (you sorry sucker :) ), it will make life easier for both of us if you're ready to invest in a scanner. You can find used ones that will work on your car that are very inexpensive, as in less than 50 bucks. I have a Monitor 4000 that does GM, Ford, and Chrysler up to '95 models. It cost over $600.00 new but it's obsolete now. Today I use Chrysler's DRB3 scanner because with an extra plug-in card it will do emissions-related stuff on any car brand sold in the U.S. after 1995. With that card it also works on older Chrysler products so I never use my older scanners anymore. A lot of independent shops also use the DRB3 or other aftermarket products that do even more, so they are selling off their older equipment. That's why you can find them so cheap on places like eBay.
You don't want just a simple code reader. You don't need those for GMs and Chryslers. With Fords, before around '91 or '92, getting fault codes out is a miserable ordeal. It can be done with a test light or voltmeter with a pointer, but it's easier with a code reader. However, the full scanner lets you view live data too. That means you can see current sensor data and see what outputs the computer is turning on and off. Some of the tests are "bidirectional" meaning not only can you see what the computer is seeing and doing, you can talk back to it and command it to do things like turn on radiator fans or the fuel pump for testing those circuits. One of the problems with the early scanners is they only access Engine Computers. My Monitor came with an extra cartridge to access Chrysler's electronically-controlled transmissions, and now I have a cartridge for anti-lock brakes, but the newer scanners can access all the computers on the cars without switching to different cartridges.
By '92 or '93 Ford had made huge leaps with their self-diagnostics, but things really improved with all the '96 models and brands. With those, there's well over a thousand potential fault codes just for the Engine Computer. In '88 all cars were pretty primitive. There may be only two or three dozen codes and they weren't very descriptive. Often they only told you the circuit that needed diagnosis, but not what the unacceptable condition was. You had to figure that out with voltage readings.
The first thing I would do on your car is start with the basics. New spark plugs and wires, and a distributor cap and rotor. Eliminate the easy and common stuff, then if the problem is still there, we'll have to look into fuel pressure and ignition timing. Ignition timing can be erratic if there's wear in the bushing in the distributor or if the timing chain is stretched.
Also check for vacuum leaks. Don't forget that fresh air tube between the mass air flow sensor and the throttle body. Leaks there are a real common cause of hesitations and stumbles during acceleration, and surging at steady speeds.
CHUCKYB10
  • 17 POSTS
Yes I will check for one of them monitors, and I wish I already knew the basics, to auto care, hey thanks, maybe this info could help with my info to you, sometimes it sounds like almost a back fire, its not the original motor its a motor out of a 96 mustang, and wat causes the motor to not stay on when I start it, I turn it over and it will turn off
CARADIODOC
  • 34,412 POSTS
You mean the starter cranks the engine okay, the engine starts and runs after you release the ignition switch, then it stalls a few seconds later? If that is right, the first thing to look at is if you get the nice "idle flare-up" to 1500 rpm when the engine starts. If you do not, . . . in fact, if you have to hold the accelerator pedal down 1/4" to get the engine to start and stay running, that is a problem with the idle air control (IAC) valve. The valve itself doesn't seem to cause a lot of trouble. A better suspect is a loose or corroded terminal in its electrical connector. By the way, the clue is the engine WILL stay running as long as you keep your foot on the gas pedal. If it stalls anyway, that is a fuel supply issue.
The throttle body takes the place of the carburetor used on older cars. It just has the throttle blade and controls only the air flow., not the fuel metering. A throttle position sensor sits on the side of it but it has rather little to do with fuel metering. If you don't know what to look for, you can follow the fresh air tube from the air filter to the throttle body where that tube attaches. You can also look for the throttle cable. It's attached to a quarter-round cable guide that sits on the side of the throttle body.
CHUCKYB10
  • 17 POSTS
Thanks for your info, and that sounds like that's the problem, I do have to hold the pedal down. Crazy, so now that's what is wrong, how can I change the idle air control valve.
CARADIODOC
  • 34,412 POSTS
The IAC valve is held on with two bolts, but it doesn't fail very often. Corroded terminals in the connector are more common. Before you spend money on a new valve, measure the resistance between the two terminals for continuity. You can also use a pair of small jumper wires to apply voltage with a flashlight battery. With the engine running, the 1.5 volts should cause a noticeable speed increase. If it does, the valve is okay. If it doesn't, first remove the valve and check that the passages aren't plugged with carbon.
CHUCKYB10
  • 17 POSTS
The connectors need to be changed if they're corroded. How would I do this myself, and have you heard of the big banana scanner.
Oct 19, 2020 at 9:52 AM (Merged)
CARADIODOC
  • 34,412 POSTS
Easiest is to cut off a clean connector in a salvage yard. You can buy most connectors at auto parts stores too. Splice the wires, then seal the connections with heat-shrink tubing. Never use electrical tape because that will unravel into a gooey mess on a hot day. Most of the time the terminals can be cleaned with contact cleaner and a small wire brush. If you can pull the terminals out, you can often use sandpaper too to shine them up.
I haven't heard of that scanner. Look for one from a company that is still in business so you can get updated cartridges or operating information. The Monitor 4000 was made by OTC which made the Chrysler DRB2 that looked almost the same. Snapon is another popular brand but they are very proud of their products and charge accordingly for them. Genysis is another popular brand that is a lot less expensive than Snapon stuff, but I don't know how far back they go.
CHUCKYB10
  • 17 POSTS
Now it won't even start, maybe its outta gas
CARADIODOC
  • 34,412 POSTS
Check the fuel pressure or see if it runs on starting fluid.
CHUCKYB10
  • 17 POSTS
Ok I will, how do I check the fuel pressure, and where would I spray the starter fluid.
CARADIODOC
  • 34,412 POSTS
There should be a test port on the fuel rail on top of the injectors. You can open the fresh air tube anywhere and spray starting fluid in.
CHUCKYB10
  • 17 POSTS
What if there's no m a f on my car
CHUCKYB10
  • 17 POSTS
No maf in air intake
CARADIODOC
  • 34,412 POSTS
Gotta have one if you have fuel injection. Only Chrysler has never used a mass air flow sensor.
I can't find any listing for a mass air flow sensor for your car. There are listings for the throttle body, so now I'm confused. At any rate, you should be able to open the fresh air tube someplace to spray in starting fluid.
CHUCKYB10
  • 17 POSTS
So lol there's not a mass air flow sensor on my car?
and do I have to drain the oil to put a oil sendinding unit on
CHUCKYB10
  • 17 POSTS
And what else can I do to increase a lil horsepower and get my motor lean
CARADIODOC
  • 34,412 POSTS
If you're changing the oil pressure sending unit for the dash gauge or light, you don't have to drain the oil. A little will dribble out. You just don't want the engine running while you do that or you'll have a dandy surprise.
You're the third Ford owner today to ask about more power. What do you mean by "more lean"? The Engine Computer monitors the fuel mixture in the exhaust and it fine tunes that mixture for the lowest emissions. There are some things you can do to trick the computer into commanding more fuel, but you'll be lacking the additional air needed to get any power from that gas. You're limited by the volume of the cylinders.
One thing we used to do on racing engines was to change the camshaft timing. Two degrees makes a huge difference in the personality of an engine. Your camshaft sprocket is positioned by a dowel pin in the camshaft. You used to be able to buy a new sprocket with multiple dowel holes. You selected the hole that provided the amount of change you wanted. They were really meant for "blueprinting" an engine which just means building it exactly to very tight original specifications, but they were available to build the engine for specific purposes too. You also used to be able to buy offset dowel pins to accomplish the same thing.
If you remember "T" for "tight, "T" for "top end", and "T" for, . . . uhm, . . . "advanced", if you would tighten the pulling side of the timing chain that would advance the camshaft making the valves open sooner. That would increase torque at the high end of the rpm range.
If you remember "L" for "loose", "L" for "low end", and "L" for "late", a loose timing chain will make the valves open late and that will increase low-end torque while sacrificing high-end torque. This is typically done in motor home engines that need the torque on the low end to get going at stop signs. You won't pass anyone at highway speeds with those engines without a mile head start.
I have a 440 c.i. out of a highway police car. Everyone knows those are major powerhouses, but mine goes from 0 to 60 mph like any old 318 c.i.. From 60 to 90 it comes alive and just about tears the seats off the hinges! It was made for highway pursuit and the cam timing was tailored for that.
I also have a 318 c.i. that I totally rebuilt, and used a gas mileage camshaft. Come to find out it was the exact same part used in motor home engines. I could squeal the tires all over the place with the additional low-end torque, and it did increase the fuel mileage on that big old station wagon.
A lot of people notice their tired old engines seem to have lots of power when taking off but they have a hard time passing other cars on the highway. That is due to a worn timing chain that makes the valve timing late. Simply replacing the worn chain and sprockets will restore the high-end power.
Thanks to the politicians and tree-huggers, there isn't much else you can do. The exhaust system is already plenty free-flowing even with the catalytic converters. Anything else you can modify to get more power is going to increase emissions, and that's where the rub comes in. We used to install camshafts with different valve overlap and duration but those just moved the power band around to the desired range for a specific purpose. You have to increase the compression ratio or the volume of the cylinders to get more power. Short of adding a turbocharger to stuff in more air, there's no practical way to get more power.
CHUCKYB10
  • 17 POSTS
O I mean it lifts the front end, but to run harder and not risk hurting the motor
CARADIODOC
  • 34,412 POSTS
There really isn't much else you can do. You're already at what was designed in. The automotive marketing is so extremely competitive, if they could get one extra horsepower, one more cubic foot of leg room, or one more cup holder that they could advertise, you can be sure they would have done it.
CHUCKYB10
  • 17 POSTS
Flowmasters ?
CARADIODOC
  • 34,412 POSTS
Doubtful. The exhaust system is already so low on restriction. That's why catalytic converters are so much larger in diameter than the rest of the pipes. They are not the largest restriction in the system. That is the pipes.
CHUCKYB10
  • 17 POSTS
Hows it going, got a question, is it normal for my engine to still be hot 30 to 45 mins later after being driven pretty hard.
CHUCKYB10
  • 17 POSTS
How can I keep my engine cool.
CARADIODOC
  • 34,412 POSTS
Depends on the outside temperature. If it's 60 degrees, yes, the engine will be hot for a while. If there's no indication it's overheating, you can connect a scanner to see what the actual coolant temperature is. If it's staying around 200 to 210 degrees, there is no problem. You don't want it running too cool. You want the gas to vaporize properly in the intake manifold and you need the oxygen sensors up to 600 degrees so they will report an accurate mixture reading to the Engine Computer. Oil that's too cool will not burn off the blowby and raw fuel that get into it. That causes sludge and increased wear.
CHUCKYB10
  • 17 POSTS
O sounds good. I think everything is fine just double checking and I also had a problem with the alternator plug? Sensor connected to the altenator.
