2002 Ford Crown Victoria Roaring Noise and Metal Crunching
2002 FORD CROWN VICTORIA
139,800 MILES • V8 • 2WD • AUTOMATIC
JPELLICIER
  • 9 POSTS
I Am Hearing A Roaring Noise Coming From The Front Of The Car. It Sounded Like The Tires Were Bad So I Replaced Them But The Noise Persists And Gets Louder As I Accelerate. I Am Pretty Sure Is Coming From The Front Driver Side Wheel But I Was Told That It Could Also Be The Differential. Also When I Turn The Wheel All The Way (any Side) And The Car Bounces I Hear A Horrible Noise, Like Metal With Metal Crunching. What could be causing this noises?
Oct 27, 2008 at 1:53 PM
DONITIA
Your bearings in the wheel cylinders are bad. In fact VERY bad.
Jan 25, 2016 at 4:18 AM
DONITIA
If your hearing a creaky sound in addition to the roaring sound, you may need to get the ball joints replaced.
Jan 25, 2016 at 4:23 AM
