2001 Ford Crown Victoria power window repair
MOWEN
The driver side window has been giving trouble (i.e going very slow, sometimes not going up at all unless you actually pull on the glass, etc...).
I have taken car to Dealership to check on this-(it was suppose to be under warranty but wasn't).
Dealership claims that the window regulator needs to be replaced. I can purchase the parts at my local parts house but how can I do this repair myself?
Dec 30, 2008 at 11:02 AM
DAVE H
  • 13,384 POSTS
WINDOW MOTOR
Removal & Installation (Front Door)
Remove door trim panel and protective shield. Place window glass in full up position and tape window in place. Disconnect negative battery cable. Disconnect window motor harness connector.
Using a 1/4" drill, remove 3 window regulator motor bracket rivets from door. Move motor, with drive cables attached, so motor retaining screws can be accessed. Remove window motor Torx retaining screws.
Separate window motor from window regulator. Remove window motor through access hole in door. To install, reverse removal procedure. Tighten motor-to-regulator bolts to 53 INCH lbs. (6 N.m).
Dec 30, 2008 at 11:24 AM
