2001 Ford Crown Victoria bent or stuck valve in #1 cylinder
104,000 MILES • V8 • 2WD • AUTOMATIC
UBDOUBLE
"guesstimate" to repair a stuck/bent valve on a Crown Vic PI (4.6L engine) (Ford suggests replacing the entire engine @$3200.00) - I suspect that's rather excessive!
Mar 17, 2009 at 10:32 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:6d0971ca5c="ubdouble"]Engine Mechanical problem
2001 Ford Crown Victoria V8 Two Wheel Drive Automatic 104000 miles
"guesstimate" to repair a stuck/bent valve on a Crown Vic PI (4.6L engine) (Ford suggests replacing the entire engine @$3200.00) - I suspect that's rather excessive![/quote:6d0971ca5c]
As long as there is no other damage. A gesestimate would be $800 - $1,200.
Are you sure it is a valve? What is the problem.
Mar 17, 2009 at 10:39 AM
UBDOUBLE
Just got the vehicle back from Palmetto Ford (here in Charleston). I had requested they identify the "Check engine" light problem- per them, low (no) compression on the # 1 cylinder, so they pulled the valve cover to check and found either a "stuck or bent valve" (their words) on the #1 cylinder. Since I don't want to spend their estimate ($3200) for repair, they put the vehicle back together, leaving the rocker arm (for the bad valve) off. The vehicle still runs, but I'm holding my breath (slightly).
Mar 18, 2009 at 12:38 AM
