2000 Ford Crown Victoria rough running
2000 FORD CROWN VICTORIA
159,000 MILES • V8 • 2WD • AUTOMATIC
SJ5096
check engine light is coming on had diagnostic test done at auto shop shows that number 8 cyllinder was advised to replace fuel injector. Replaced it and coil and spark plug, check engine light still coming on and car is running rough and step into it and it picks iup and then starts cutting out again, will do at idle and while driving. Any suggestions would be appreciated.
May 27, 2010 at 2:18 AM
Check no.8 cylinder compression
May 27, 2010 at 2:32 AM
