2000 Ford Crown Victoria rear inner wheel seal leaks
2000 FORD CROWN VICTORIA
84,000 MILES • V8 • 2WD • AUTOMATIC
BARTOLO
do you know any sealant and conditioner to stop leak on rear axle shaft due a bad seal,and what gear oil must be used for refill the differential
May 19, 2008 at 10:29 AM
BLACKOP555
  • 10,386 POSTS
the only sealant/ conditioner for you is a seal change, using a sealer only lets it wear out more in teh process and then you will loose all your fluid and wreck the back end. regular 40 weight gear oil should be sufficient.
May 19, 2008 at 12:11 PM
