HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Crown Victoria
Engine
Symptoms
Low Power
SPONSORED LINKS
2000 Ford Crown Victoria not sure
MIKEDS0732
MEMBER
2000 FORD CROWN VICTORIA
Engine Performance problem
2000 Ford Crown Victoria V8 Two Wheel Drive Automatic
when ac is running the engine tends to lose power gets worse while long time use
Tuesday, June 22nd, 2010 AT 1:42 PM
MECHANIC
It is normal for a slight loss of power. Is it slight or very noticeable?
SPONSORED LINKS
Thursday, July 1st, 2010 AT 9:51 PM
MIKEDS0732
MEMBER
It almost feels like im startting to ride with my brake on, I have to push more on the gas the longer I run it
Friday, July 2nd, 2010 AT 7:22 AM
MECHANIC
Has the check engine light come on? Also, have you checked fuel pump pressure and the catalytic converter for plugging?
Friday, July 2nd, 2010 AT 1:09 PM
Please
login
or
register
to post a reply.
Related Engine Low Power Content
Crown Victoria....sparks Under Hood Makes Awful Noise...
Sparks Under Hood Makes Awful Noise Also Will Not Go Over 40 Mph Battery Light Is Also Coming On Helpppp
Asked by
julie592001
1 ANSWER
2000
FORD CROWN VICTORIA
VIDEO
Fix an Engine with Low Power!
Instructional repair video
GUIDE
Symptoms of Low Engine Power
The power your car's engine is producing is important. When you step on the gas you need your car to accelerate, mainly to keep you out of trouble when getting onto the...
2000 Ford Crown Victoria Transmission Will Not...
Just Replaced The Intake Manifold And Now Realized The Tranny Fluid Was Low And Added Fluid. Its Shacky And Thought It Needed Time To Get...
Asked by
foxcarservice
2000
FORD CROWN VICTORIA
1997 Ford Crown Victoria Fuel Relay Has No Power To...
I Have A 1997 Crown Victoria Police Interceptor And I Have No Power To The Fuel Pump. I Have Jumped A Hot Over The Inertia Switch And Runs...
Asked by
raceme0911
1997
FORD CROWN VICTORIA
Poor Runnability, Bogs Down On Acceleration
Working On A 2008 Crown Vic Police Cruiser W/ A 4.6l, Vin #2fafp71v68x127296. Has Been In For Runnability Issues, Only Codes Ever Set...
Asked by
quinton.payne
2 IMAGES
2008
FORD CROWN VICTORIA
1991 Ford Crown Victoria Loss Of Power Up Hills
This Car Was Bought From It's Original Owner, But Had Sat Idle For Several Months. It Ran Ok Until It Had The Trans Fluid Changed And A...
Asked by
climbingivy
1 ANSWER
1991
FORD CROWN VICTORIA
VIEW MORE
SPONSORED LINKS
Catalytic Converter Test
Online car repair manuals
