Engine Performance problem
2000 Ford Crown Victoria V8 Two Wheel Drive Automatic
broke down and bought a manual. a must have. first, found out number 1 plug is on passenger side, not driver side. so coil i changed was in wrong place. swapped that, cleared codes in computer and went for a drive. helped, but not all hesitation gone. then got another code! bad upstream o2 sensor on bank 1. (passenger side). replaced that, car runs smooth as silk. hope this helps someone else. if at first you dont succeed, yadda yadda.. good luck!
May 30, 2009 at 1:06 AM
