2000 Ford Crown Victoria Engine Hesitation
ENZORUBBINO
  • 2000 FORD CROWN VICTORIA
  • V8
  • 46,000 MILES
I recently degreased the motor of my 2000 P71 crown vic and was carefull to cover all the electrical parts and not get them wet. After hosing down the motor I let it dry and went out to run some errands and felt the car sputter at cruising speeds. On hard excelleration the motor hesitates and feels underpowered now. Car is welltaken care of and has just over 46,000 miles. I am nit sure if I screwed up a coil or plug. Any ideas?
Thanks.
Tuesday, August 25th, 2009 AT 11:46 PM
WAY2OLD
  • 195 POSTS
It is highly likely you got water in one of the plug wells. If you have access to a scanner you can check Mode$06 and see which cylinder is misfiring. If the check engine li ht is on have the code read at an auto parts store.
Friday, September 11th, 2009 AT 12:25 PM
