1999 Ford Crown Victoria transmission lever stuck in park
1999 FORD CROWN VICTORIA
TOTOTOOV
Electrical problem
1999 Ford Crown Victoria Automatic 49000 miles
the transmission lever on my 1999 ford crown victoria is stuck in park & I have no brake lights.I know how to put the shifter in neutral manually but I need advice on the repair so when I put my foot on the brake it releases the transmission & I need brake lights.My guess is the 2 problems are connected-where do I find the brake switch & is that the probable cause?
Oct 1, 2009 at 8:50 AM
WAY2OLD
  • 195 POSTS
The brake light switch is located up on the brake pedal arm where the rod from master cylinder connects to it. You will see a switch there. Look at the connector closely also. They are known to break.
Oct 1, 2009 at 11:52 AM
TOTOTOOV
I've narrowed it down to the brake switch being the problem.the switch goes through a metal support & I can't figure out the release clip for the switch removal under the dash.The switch appears to be in a holder which goes through this metal support.Is the switch separate from the plastic holder or is it all one?I don't want to break the retainer.
Oct 2, 2009 at 12:14 PM
WAY2OLD
  • 195 POSTS
Here sre Autozone's instructions.
Removal & Installation
1.Disconnect the negative battery cable.
2.Disconnect the electrical connector at the switch. The locking tab on the connector must be lifted before the connector can be removed.
3.Remove the hairpin retainer, slide the brake light switch, the pushrod and the nylon washers and bushings away from the pedal and remove the switch.
NOTE
Since the switch side plate nearest the brake pedal is slotted, it is not necessary to remove the brake master cylinder pushrod and 1 washer from the brake pedal pin.
To install:
1.Position the switch so the U-shaped side is nearest the pedal and directly over/under the pin. Then slide the switch down/up trapping the master cylinder pushrod and black bushing between the switch side plates. Push the switch and pushrod assembly firmly toward the brake pedal arm. Assemble the outside white plastic washer to the pin and install the hairpin retainer to trap the whole assembly.
2.Assemble the wire harness connector to the switch. Check the switch for proper operation.
Oct 4, 2009 at 11:09 AM
