1999 Ford Crown Victoria sparks coming from crank pulley
87,000 MILES • V8 • 2WD • AUTOMATIC
SLIMJJBS05
changed crank sensor twice my question now can it be a bad timing ring on the crank it sparks all over crank pulley and affects the timing it is erattic no pattern some time nothing but getting worse some times a bad miss but no codes nothing behind crank pulley all wires ok dont know im stumpped
Sep 26, 2010 at 1:59 PM
  • 110,246 POSTS
Check the ground to the engine block.
Let me know what you find.
Sep 27, 2010 at 2:40 PM
