1999 Ford Crown Victoria ignition coils
175,000 MILES • V8 • 2WD • AUTOMATIC
CRANDADDY
  • 6 POSTS
I have a 1999 ford crown vic interceptor. The ignition coils keep going bad. Is there something that can cause this?
I keep replacing coils but that gets expensive.
Mar 10, 2010 at 3:56 AM
DOCFIXIT
  • 18,828 POSTS
All eight coils or just certain one?
Mar 10, 2010 at 4:43 AM
CRANDADDY
  • 6 POSTS
Its all eight coils. I have replaced several and dont remember which ones. Right now 2, 6 and 7 are missing.
Thanks
Mar 10, 2010 at 4:48 AM
DOCFIXIT
  • 18,828 POSTS
How many miles on plugs? Motorcraft AWSF-32PP or equivelant?
Mar 10, 2010 at 5:04 AM
CRANDADDY
  • 6 POSTS
probably 20,000 or so on plugs?
Not sure on brand. Should I just try new plugs?
Mar 10, 2010 at 5:10 AM
DOCFIXIT
  • 18,828 POSTS
Could be the problem if plugs wrong type or gap incorrect would cause coils to heat up. Also good to ues Dielectric jell on plug contact.
Mar 10, 2010 at 5:21 AM
CRANDADDY
  • 6 POSTS
Is there something that regulates the voltage sent to the coil? Like 12 volts when starting the car and down to 6 volts when running? Perhaps stays at 12 volts for some reason and damages the coils?
Mar 10, 2010 at 5:33 AM
DOCFIXIT
  • 18,828 POSTS
Nope they get 12 all the time and ECM grounds to fire. Using Motorcraft or aftermarket coils?
Mar 10, 2010 at 5:58 AM
CRANDADDY
  • 6 POSTS
I have replaced with aftermarket. I have been told that aftermarket are made to ford specs?
Mar 10, 2010 at 6:20 AM
CRANDADDY
  • 6 POSTS
Do think the aftermarket are OK to use? Some say definitely not.
Thanks
Mar 12, 2010 at 5:01 AM
DOCFIXIT
  • 18,828 POSTS
I would use OEM with all the stuff coming out of China you never know what you get
Mar 12, 2010 at 5:13 AM
