1999 Ford Crown Victoria electrical problem
1999 FORD CROWN VICTORIA
87,000 MILES • V8 • 2WD • AUTOMATIC
SLIMJJBS05
crank pulley is arcing
Sep 22, 2010 at 1:35 PM
WAY2OLD
  • 195 POSTS
The only way a crank sensor can arc is if the crank sensor is hitting the sensor ring. Or possibly something has fallen behind the pulley. There is nothing electrical connected to the pulley. Check the sensor down behind the A/C compressor. If that is where the arc is coming from, you can replace sensor easily.
Sep 23, 2010 at 12:07 PM
