1999 Ford Crown Victoria air bag blink codes
78,000 MILES • V8 • 2WD • AUTOMATIC
DASMITH
can you advise what 2-4 means?
Feb 25, 2009 at 2:05 PM
BMRFIXIT
  • 19,053 POSTS
The ECS module monitors back-up power supply, accelerometer operation and memory. If ECS detects a failure in these components, it will store DTC B1342 in memory and flash Code 24 on AIR BAG warning light.
Possible Causes
An ECS module internal fault could be caused by improperly operating accelerometer, back-up power supply, internal module circuit fault or microcontroller RAM/ROM/EEPROM
Feb 25, 2009 at 7:57 PM
DASMITH
Where is the ECS Module? Is this something the average person could replace with something from a junker?
Feb 25, 2009 at 11:57 PM
BMRFIXIT
  • 19,053 POSTS
Its no a job that I would recommend to be done at home or the use of a used parts
Feb 26, 2009 at 4:53 AM
