1998 Ford Crown Victoria Rear end
1998 FORD CROWN VICTORIA
LORENNBL
  • 13 POSTS
Shakes or Wobbles problem
1998 Ford Crown Victoria V8 Two Wheel Drive Automatic
had a 1998 ford crown vic rear end replaced....after it came back it now has a shudder...but ONLY when the brakes are applied....ideas? I was told it was a sensor that didn't recalibrate itself, but I have never heard this one...
Mar 14, 2010 at 11:54 PM
TOOOMANYTOYS
  • 513 POSTS
When the differential was replaced was it with a used on. It may be possiable if it was used that they used the rotors or drums from the used diffential. If its not coming from drums or rotors I would suggust checking the axle flange run out. Should be no more than .003 run out.
Mar 15, 2010 at 12:03 AM
