1998 Ford Crown Victoria Fuel Pump
1998 FORD CROWN VICTORIA
169,800 MILES • V8 • 2WD • AUTOMATIC
BKC1
I have a 1998 Crown Vic it has been sitting up for about 15 months it ran fine when it was park but I tried to crank it and it does not act like it is getting gas in the passed i could hear the fuel pump running when you turned the key on now i can not hear this is it possible the fuel pump went bad while sitting up or is this going to be a fuse or what
Feb 16, 2010 at 9:35 AM
Power the fuel pump direct from the battery if it comes On and produces the correct fuel pressure check fuel pump fuse and relay-
Feb 16, 2010 at 9:58 AM
