1998 Ford Crown Victoria BATTERY LIGHT
1998 FORD CROWN VICTORIA
KEVIN JACKSON
Electrical problem
1998 Ford Crown Victoria V8 Automatic
IN MY 98 FORD CROWN VICTORIA MY BATTERY LIGHT COME ON SOME TIME AND THEN GO OFF AND WHEN THE LIGHT NOT ON MY BATTERY AND ALTERNATOR TEST GOOD
Jan 27, 2010 at 10:59 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The battery light is indicating a low or no charge state, you may have a problem with the voltage regulator , you will have to get the system tested while the light is activated other wise you will not get a correct diagnosis.
mark (mhpautos)
Jan 27, 2010 at 11:44 AM
KEVIN JACKSON
THE BATTERY LIGHT DONT SAY LOW OR NO CHAGE IT JUST COME ON SOME TIME MY BATTERY VOLTAGE IS 12.63. IS IT SOMETHING I CAN DO TO MAKE THE LIGHT COME TO GET IT CHECK. CAUSE EVERYTIME I GET BY THE PARTS PLACE ITS NEVER COME ON. WHAT ALL CAN IT BE
Jan 27, 2010 at 11:53 AM
  • 31,937 POSTS
HI there if you try and simulate the problem that will defeat the purpose, i am fairly sure that the problem will be in the alternator voltage regulator, but the only way to check this is to do the test when it has come on by its self.
mark (mhpautos)
Jan 27, 2010 at 12:09 PM
WAY2OLD
  • 195 POSTS
When the light comes on, wiggle the little wire on the top of the alternator. If the light goes out, squeeze the connector to make a better connection. This is a common problem on the CV.
Jan 28, 2010 at 10:55 AM
