i changed my fule pump amd i have sum wires in the inside of my tank that are exposed what do i need to do to make sure i fix ths right
Oct 3, 2010 at 5:16 AM
BLUELIGHTNIN6
✓Experienced Mechanic
you mean the insulation has came off of the wiring in the tank? if so then the wiring harness really needs replaced to fix it correctly, otherwise you could add some heat shrink wire wrapping to insulate the wiring again..
