1997 Ford Crown Victoria fule pump
1997 FORD CROWN VICTORIA
220,000 MILES • V8 • 2WD • AUTOMATIC
JLINDSAY
i changed my fule pump amd i have sum wires in the inside of my tank that are exposed what do i need to do to make sure i fix ths right
Oct 3, 2010 at 5:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you mean the insulation has came off of the wiring in the tank? if so then the wiring harness really needs replaced to fix it correctly, otherwise you could add some heat shrink wire wrapping to insulate the wiring again..
Oct 3, 2010 at 1:21 PM
