1997 Ford Crown Victoria engine runs hot
1997 FORD CROWN VICTORIA
214,000 MILES • 6 CYL • FWD • AUTOMATIC
J.CHARITY
What is the problem when water leaks from the exhaust pipe and the car runs hot?
Jul 17, 2010 at 11:03 AM
WAY2OLD
  • 195 POSTS
If it is antifreeze running out of the pipes, the head gaskets are shot. If it is clear or black water, that is just condensation. If it is the latter, copuld be a plugged radiator, bad thermostat, bad water pump, bad cooling fan.
Jul 17, 2010 at 2:20 PM
