1997 Ford Crown Victoria ENGINE KNOCKING INSIDE THE VAL COV
1997 FORD CROWN VICTORIA
MYCARPROBLEM
Engine Performance problem
1997 Ford Crown Victoria V8 Four Wheel Drive Automatic
HOW I STOP THE SOUND AND CORRECT THE PROBLEM?
Aug 20, 2009 at 10:25 AM
JUNIOR2
  • 7 POSTS
Is your motoring is for the valves sticking and the push rods falling off of the overhead cam.Mostly if the car has sat for a while or bad gas.It can also be a collapsed lifter stuck due to some trash or dirt in the lifter,If so there are over the counter motor flsh but most of the time its diesel fuel that helps do the job of cleaning engine sludge and dirt out of a motor.Or you could possibly have a bad lifter.Also you might check your oil pressure to see if you have enough pressure to lubricate all the lifters.
Sep 1, 2009 at 7:00 AM
WAY2OLD
  • 195 POSTS
Just for giggles, remove the PCV and see if noise goes away.
Sep 11, 2009 at 5:53 AM
