[quote:476f53f6a3="bearsxxx"]Heater problem
1997 Ford Crown Victoria V8 Two Wheel Drive Automatic 110000 miles
i need chabge the heater core[/quote:476f53f6a3]
Be aware that it may take up to 6 or 8 hours to do this. You have to remove the dash in order to do it. disconnect the battery, remove the steering column, remove the dash, remove the heater plenum, then you can seperate the plenum to get to the heater core. BE VERY CARFULL NOT TO LET THE STEERING WHEEL TURN AFTER REMOVAL. this could damage parts affecting the airbag and cruise control.
Dec 7, 2007 at 1:42 PM
